Cluster into array of bit
Hi
Well, my title is my question. Is it possible
to transform a cluster to an array of bit ? I am
on LabView 5.1.
Thanks in advance
(2,646 Views)
Sure. In LabView 6.1 there's a Cluster to Array function in the Array or Cluster palette. If that's not available in 5.1 you can use the Unbundle function (in the Cluster palette) then the Build Array function (in the array palette).
(2,646 Views)
