Cluster based popup works in Dev but not as Exe
Hi all,
I'm using an old toolkit TS Popup to allow user to enter data into a multicolumn listbox: https://lavag.org/topic/10282-cr-type-sensitive-popup/
Consist of an invisible cluster containing different control types which montiors for click events on multicolumn listbox.
Works in dev environment but not in exe.  The click into cell works but not when you click out.
How could something like this work in dev and not exe?
(3,072 Views)
Accepted by topic author battler.
Deja vu?
If you look at the LAVA thread you linked to, you asked the same question there and I answered it saying that there are VIs which need to be explicitly included in the EXE. I suppose if you look for the NI forums thread mentioned there you will find more details.
___________________
Try to take over the world!
(3,069 Views)
Thank you 🙂
(3,056 Views)
