Cluster Bundle. Create or Replace?
Hi all,
I have a quick question.. When one bundles a cluster is it quicker/better to add a constant on the top connector of the bundle so that LV each time replaces the elements or is it better to leave this option blank so that the cluster is created every time?? Or does it not make any difference at all?
Cheers,
Harry
(2,538 Views)
You need to connect to the top if you want to bundle by name, which is always much more self-documenting that a plain bundle operation.
Typically you also wire on top if you keep the cluster in a shift regsiter and only want to replace a certain subset of cluster elements, (again using bundle by name).
I don't think that you need to do it for a simple bundle operation....
(2,525 Views)
