Cluster - Broken Wire
Good morning,
I have been battling to create a cluster that represents temperature, date, & time. The ultimate goal is to display 12 temperatures that correspond with a date and time. I continue to receive a broken wire error. Any and all help is appreciated.
(1,605 Views)
Well, you are bundling together arrays of items, but your indicator only contains scalers.  So the clusters are not the same.  I would recommend doing the bundle inside of the loop and change your indicator to be an array of the cluster.
(1,601 Views)
And if you right-click on the output of the bundle (or on the output tunnel of the for-loop after following crossrulz tip), you can create the indicator of the correct type directly so you don't have to struggle with manually trying to create the correct type
Certified LabVIEW Architect
(1,587 Views)
Thank you. I was currently, struggling to figure that part out.
(1,573 Views)
