Closing reference, doesn't close everything
Hi all!
I run into a problem with a .Net library (EasyModbus.dll (5.6.0)). Some time I'm getting some connection error, and I disconnect the device, close the reference of .Net, than connect again, make the reference new. I'm doing this until, the connection is establishing. Today I've got a different connection error, I did the same, but here the connection cannot established, only when I close my program and open it again.
What you think, what is the difference, between CloseReference.VI and closing my program?
Thanks for the tips!
(2,092 Views)
For another .NET library (for SSH), I also had to call a "Dispose" method in order for it to close properly.  Perhaps you have another similar method.
(2,087 Views)
@robert.eva wrote:
Hi all!
I have never used Easy Modbus but I have used the NI Modbus library and found it to be fully functional and very easy to use.
LabVIEW Modbus API
=== Engineer Ambiguously ===
(2,036 Views)
