Close Project will abort VI, but WHICH ONE?
LV 2013, Win 7
So, I get this dialog If I do a certain something in my program, undo it, close the VIs and try to close the project.
Is there a way to find out WHICH Vi(s) are still running?
I have 75+ threads running in the whole program, the "certain something" narrows it down to about 20.
One of them has gone rogue, but LV is not telling me which one.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(4,161 Views)
Accepted by topic author CoastalMaineBird
This is my very helpful "oh crap"-vi when i get stuck with Modal VI's or similar. Just remove the Abort action and you'll get a list of all active ones. 🙂 (Well you will anyway, but as a list of what was aborted)
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,155 Views)
I found this VI on the forums years ago.  I don't remember exactly where.  It allows you to choose which VI's to abort.
(4,136 Views)
YES!     Thanks, Yamaeda !
I guess I could have chased that down, but your VI saved me the trouble.
It shows that I have about 20 VIs still running.
Probably the fault of only one of them, but I can figure it out now.
This should be in the LabVIEW DevSys.
Steve Bird
Culverson.com
LinkedIn
(4,131 Views)
Well, that's not as helpful as I thought.
I get a list of 64 items that it found.
Most of them are controls, but those give me error 1035 (Operation not valid for this type of VI).
The actual VIs give me error 1000 (VI not in state compatible with this operation).
It doesn't kill any of them - if I run it again, it shows the same list of 64.
Steve Bird
Culverson.com
LinkedIn
(4,120 Views)
OK, I found the trouble with conventional means:
I was issuing two events: SHUT DOWN and DESTROY to instances of a class.
But the class was UNREGISTERING FOR EVENTS on the first one amd never seeing the second.
A friend did PM me this hint - the VI HIERARCHY will show things that are in memory (even after I closed all the visible ones), with the top-level one(s) at the top.
Handy to know - just close everything and look at the hierarchy - it should show nothing but the project itself.
Steve Bird
Culverson.com
LinkedIn
(4,088 Views)
