Clone each element in a 1d array multiple times to create a new 1d array
For an example 1d array [1,2,3,4,5,6], how to duplicate each element 5 times for instance, to generate a new 1d array as [1,1,1,1,1,2,2,2,2,2,3,3,3,3,3,4,4,4,4,4,5,5,5,5,5,6,6,6,6,6]?
(5,675 Views)
This seems trivial. What have you tried so far? What is your LabVIEW version?
(5,665 Views)
Accepted by topic author findout
I'll give you the tip you build your own logic.
If you have 2013 version:
For loop and Initialize array
If you have the earlier version:
For loop, Initialize array and shift register
(5,659 Views)
Hi findout,
that is a question that you can solve by reading some free tutorials, but I am going to show you a very simple example of how you can do it (if your LV version supports the auto-indexing).
Hope it helps, regards!
(5,601 Views)
@Luis32 wrote:
... show you a very simple example of how you can do it (if your LV version supports the auto-indexing).
All LabVIEW version support auto-indexing. Older version don't support he concatenating output tunnel you are using.
Also, the "replicas" control belongs outside the loops, it should not change during exection.
(5,588 Views)
Thanks. I created a similar VI with additional Reshape Array function to convert the output into a 1d array.
(5,566 Views)
