Client view vi webpage without needing run time engine
I am trying to create a environmental webpage attached to a Labview vi where end user can browse the web page from their home computer internet.  Problem is I read that the end user need to have the Run Time Engine installed in their computers, now this sucks. If the end users need to remember to install run time engine to every computer their visit, there will no business.  Is there someway to bypass this?
https://www.ni.com/docs/en-US/bundle/labview/page/creating-html-documents-and-embedding-front-panel-...
"If you want clients who do not have LabVIEW installed to view and control a front panel remotely, they must install the LabVIEW Run-Time Engine, then view the front panel remotely."
(2,712 Views)
Accepted by topic author sunflower2772
Hi sunflower2772,
if you want to use the NI function of webserver, then you have to install the runtime engine (there is also a smaller one), the same as using some JAVA code.
If you don't want to do this, then you have to write your own webserver.
Mike
(2,691 Views)
