Client Server Application Problem ;
Data is not received to two clients simultaneously . Data is received correctly to first connected client only
(3,566 Views)
What protocol are you using (TCP/UDP/DataSocket/....)?
Norbert
Norbert
Expert: Geometry
(3,562 Views)
Thanks a lot Norbert
I am using the following protocals on each PC i.e server and Client.
Protocal
TCP/IP
Port 3360
Service Name
Main Application Instance/VI Server Use Default [checked]
[checked] ActiveX
Accessible Service Resourse
[checked All]
Machine Access
Exported VI
I am Useing LabVIEW 2009
Regards Shahid
(3,517 Views)
Shahid,
what you are listing is VI Server access. This is not intende for data transfer but for "remote control".
Do you have dedicated LV applications which should "talk to each other" or  do you use web interface (Web Publishing Tool)?
Can you post the code for the server/client?
Norbert
Norbert
Expert: Geometry
(3,505 Views)
