Client HTTP et SSL
De quelle manière et est-il possible d'utiliser Labview en tant que client HTTPS (SSL) ?
Message 1 of 8
(4,597 Views)
Salut,
On Windows, you can use the ActiveX container in LabVIEW and the 'Microsoft Internet Transfer Control 6.0 (SP4).'
See attachment for details (https.png).
Au revoir,
Khalid
Message 2 of 8
(4,598 Views)
Merci Khalid,
Pourrais-tu me refarie passer le fichier attavhé (pas complet).
De plus, peut-on de la même façon, envoyer et recevoir des données en HTTPS d'un serveur ?
Message 3 of 8
(4,597 Views)
Salut,
The rest of the diagram just parses out the plain text information from the HTML tags. This way I can display the information on my front-panel. It doesn't do anything fancy. Let me know if want the this HTML-tag parsing info'.
I don't understand your second question. I am still only beginning to learn French 🙂 Are you asking how to do this on the web-server? I am afraid I don't know what you're asking. Hopefully some French samaritan will step in and help you out.
Khalid
Message 4 of 8
(4,597 Views)
Salut,
Do you know how to send data to / receive data from the web server with the HTTPS protocol ?
Best Regards
Cyrille
Message 5 of 8
(4,597 Views)
Salut,
Using the Microsoft Internet Transfer Control ActiveX in LabVIEW (as mentioned earlier), you should be able to send and receive data from a server using the HTTPS protocol. You will have to use the "Execute" method, and then use the "GET" and "PUT" commands, for example.
The following MSDN has some good info' on using this ActiveX control and its methods.
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/vbcon98/html/vbconusinginternettransfercontrol.asp
Hope this helps.
Salut,
Khalid
Message 6 of 8
(4,597 Views)
Thanks for your reply and the link.
Where I can find the 'Microsoft Internet Transfer Control 6.0 (SP4)' ?
I was under Windows 2000, I can see the file 'Wininet.dll' but I can't find the properties detail in the link.
Best regards
Cyrille
Message 7 of 8
(4,597 Views)
How do i install 'Microsoft Internet Transfer Control 6.0 (SP4).' on my pc ? I don't seem to have it.
Message 8 of 8
(4,343 Views)
