Clearing variables between runs
Hello
I'm pretty new to LABVIEW.
When I run the VI multiple times it sometimes clears the output fields (such as an array or a string) and sometimes keeps results from previous runs.
How can I clear the variables between runs?
Thanks in advance
Yuri
(5,290 Views)
If you show some code, we can tell you. It all depends on how you wrote your application.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,288 Views)
Accepted by topic author iurik
@iurik wrote:
Hello
Thanks in advance
Yuri
Multiple ways
1.You can  initialize values before every run
2.you can use ReInitialize all to default (Invoke Node)
Its better to share code for clear understanding
(5,284 Views)
thanks for your help,
the initialization of the variable did the trick
(5,269 Views)
