Clearing plot (waterfall plot) data
I have a VI that needs to read datalog files from a folder, generate the waterfall plots of their FFTs and store the plots as images. However, on running the VI, although the images were generated, they do not appear to be matching the correct files. I suspect that the issue is either with sequence of executing the operations or clearing the image in the memory that was generated when the VI was run the last time.
I tried following the instructions (for the 'Graph' section) from the webpage using the following link but it was not helpful.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHc0CAG&l=en-US
Any help in troubleshooting this issue is very much appreciated.
Attached is the VI.
Thank you.
Amruth
Message 1 of 1
(656 Views)
