Clear XY Graph
I would like to ask if there is any property node to clear the data of a XY graph build using "Build XY Graph" without using the Reset input. I tried to clear it with
but it does not work. Thanks!!!
Message 1 of 11
(4,494 Views)
Writing empty x and y arrays does in fact work. You have to attach your actual program if you want any help.
Message 2 of 11
(4,490 Views)
Hi Dennis,
It does clear however when I run my program again I can still see the old data.
Message 3 of 11
(4,483 Views)
Then your original question does not make any sense since it actually does work for you. Finding a property that you can write to would not make any difference if your program structure is flawed.
Sorry, I cannot see anything in that bottom image.
Message 4 of 11
(4,473 Views)
Hi Dennis,
Sorry maybe I am not explaining my problem really clear. Wiring the emply array clear all the point on my graph, however when I start auto mode again the deleted data appear again and my new graph overlap the previous graph.
Is it possible for you to view the bottom image by right click->view image?
Message 5 of 11
(4,468 Views)
Are you using the normal XY graph or the Express? I don't think I've ever used the Express but I think there are shift registers in it that you would need to clear in the Build XY Graph function. If not, I would look at your other shift registers and see if you need to clear them.
Message 6 of 11
(4,455 Views)
Hi Dennis,
I am using express.
Message 7 of 11
(4,452 Views)
You probably have to use the Reset to clear the internal data. You can look at the block diagram of the express VI. As I said, I don't use the express VI.
Message 8 of 11
(4,448 Views)
Thanks Dennis for your help.
I guess I will just use the normal XY graph and wire it to empty array to reset it 🙂
Message 9 of 11
(4,438 Views)
The normal xy graph does not store any internal data.
Message 10 of 11
(4,432 Views)
