Class inner Cluster different from property
Hi
in my project there is a really big class
this class manage the data from a usb to serial converter from specific devices, it transfer the raw data into something i can use in the program
the data structure in USB.ctl contain a Cluster
called cumulative Error
this cluster when used on a property in the program that uses that class has an old configuration
How do I Align them?
(1,325 Views)
Accepted by topic author Matteo_R_C
the Data Structure  *.ctl is Different from the accessor
https://zone.ni.com/reference/en-XX/help/371361R-01/lvdialog/create_accessor_db/
accessors define the final Name of the property and i expected the name to Update automatically but it does this only on creation of the accessor
after you need to keep the accessor Up to date to have the same name on the property
i guess is the same on other languages that use properties, my Fault 😓
(1,253 Views)
and Read should be coherent with Write if not the Class is Broken
(1,248 Views)
