Class changes in git when creating child
Hi all,
LVOOP question brough on by using git for source control on a project.
I have a repo that contains my core classes, classes that are used by multiple projects.  When I build a new system off of these core classes, I noticed that the act of creating override methods in a child class registers a change to the parent methods in git.  Why is this? There is of course no functional change to the parent.  Is there any way to get these types of changes to stop happening or a way to better account for them in my source control?
Thanks.
CLAD
Message 1 of 11
(4,950 Views)
Hello testingHotAir,
So you have a number of LabVIEW Classes in git, when you make a new system off these classes and override one of the parent methods in a child class, git flags a change occurred in the parrent methods.  Is this correct?
Is the child class also part of the core classes or are you building that new using the parent from the new system?
What LabVIEW source control client are you using? SourceTree, Tortise, etc?
Thomas C.
FlexRIO Product Support Engineer
Message 2 of 11
(4,832 Views)
Hi Thomas,
That's correct.  I've created two repos, one for the core system and one for the new stuff I'm building on top of it.
The child class only exists in the new repo.  It is a child of one of the classes that should only exist in the old repo.
I'm using git for windows.  I gave up trying to use diff with LabVIEW so I don't have another client, just command line.
Scott
CLAD
Message 3 of 11
(4,821 Views)
Accepted by topic author testingHotAir
Hi Scott,
From what I understand about git, it registers a change has occurred if the file has been modified.
I am currently trying to determine if this behavior is occuring because of LabVIEW or git. LabVIEW has a built in Tools>Compare>Compare VIs... function. I tried to recreate your behavior by creating a simple Parent and Child.  I duplicate the Parent Method VI in Windows, then override the Method in the Child. Finally, I run the Compare with the Parent Method and the duplicated original Method to see if LabVIEW has registered any changes.  I get no differences found.  When I check the Windows Timestamp of last modification of the Parent Methods, I get an old number.  This to me indicates that the file is not changing and the git is doing something weird.
Can you please try this out to double check?
Thomas C.
Message 4 of 11
(4,779 Views)
Hi Thomas,
So your are creating a copy on disk of the parent method then overriding that copy with the child?  If so, that would be a different practice than what I'm doing.  I only have one copy of the parent method on disk (since I'm trying to re-use code).
Scott
CLAD
Message 5 of 11
(4,775 Views)
I copied the method VI in windows.  I then create an overide method in LabVIEW for the original method VI.  Then compare the copied method with the parent method.
This is just a test.  Can you please give it a try?
Thomas C.
Message 6 of 11
(4,756 Views)
I can't seem to get lvcompare to work.  The option is disabled under Tools > Compare.  I have the pro dev system so I'm not sure why it won't let me compare VIs.
CLAD
Message 7 of 11
(4,734 Views)
Ok slightly embarrassing...I forgot to commit some formatting changes I had made prior to creating the new repo.
That would have been a lot easier to detect if I could get lvcompare working with git for windows.  Can you point me to any resources for that?  The community doesn't seem to have a good solution pinned down for that.
Thanks for your help!
CLAD
Message 8 of 11
(4,723 Views)
Sounds good Scott.
The LabVIEW Tools>Compare>Compare VIs... only works from a VI Window, not the Project Explorer.  This might have been your problem with the greyed out item.
I would check the Git User Group to see if they have any resources on using compare.
https://decibel.ni.com/content/groups/git-user-group?view=blog
I also recommend trying to use SourceTree, if you haven't.
Thomas C.
Message 9 of 11
(4,711 Views)
Ok...it's still happening.  I think I figured out what is going on though.
If I set the method in the parent class to force children to override (Class Properties -> Item Settings -> Require descendant classes to override... -> TRUE) then every time I create a child override method it changes the file on disk in the parent class.  Is this caused by whatever mechanism in LabVIEW breaks the run arrow if a required override isn't present?  It doesn't really affect the code so it shouldn't be checked into git.  Is there a way to make git ignore this kind of change?
CLAD
Message 10 of 11
(4,673 Views)
