Class Not Registered
I always cringe when faced with a new instrument and the manufacturer only provides a LabVIEW driver set that uses ActiveX calls because 9 times out of 10 they do not work.
Case in point the attached Sorenson XG DC power supply Initialize.vi that returns the error:
Error -2147621124 Class Not Registerd in Ametek XG Power Supply.Ivlib:Initialize.vi
I knew I should have just ignored these and wrote my own set of SCPI vi's but I hoped using theirs would save some time...
=== Engineer Ambiguously ===
(6,272 Views)
I guess I forgot to ask what I can to do fix this besides abandon ActiveX and write a set using SCPI commands
(6,256 Views)
Hi RTSLVU,
Your best bet would be to contact the manufacturer (or whoever wrote the driver) if you don't get any solutions here.
G-IV
(6,203 Views)
I am having the exact same problem. Now waiting for a scheduled call from Ametek....
(5,989 Views)
Good luck with that...
I ended up just writing my own set of drivers using the SCPI commands.
Frankly I have never see an instrument driver that uses ActiveX or IVI that worked properly in well over a decade of LabVIEW programmig.
(5,986 Views)
Hello I am having the same issue now with Sorensen XG.
Originally it was working on my developing system, but I could not make it work as .exe even on developing system.
Now, I think after messing with settings, I cannot run it on my dev system either.
I get error that Class is not registered.
I did not have good luck writhing my own SCPI code. Can you please provide example for initialisation and setting voltage? I just want to make sure I understand command format right.
Thank you
(5,918 Views)
