Clarification of 'Icon' of Boolean Constant in LabVIEW
Hello everyone.
I'm learning the basics of LabVIEW and came across a question that consisted of a while loop. The conditional terminal was set to 'Continue if true' and it is wired to a  Boolean Constant as shown in the above pic (refer to the attachment). Below is the another image of while loop with same condition but the Conditional terminal is wired to a 'usual' Boolean Constant. I just want to know the difference between both Boolean constants.
Thanks.
(3,031 Views)
Accepted by topic author Ganny
Hi Ganny,
the upper image was made using an old LabVIEW version, whereas the lower loop/boolean constant is used with more recent LabVIEW versions…
(3,015 Views)
Thanks GerdW.
(3,009 Views)
