Clad
Hiii friends,
I have attaached the doc which contains 6 questions .. i that i have already marked some answers.... if i have mared as wrong plz say the correct answer........
(3,891 Views)
Are you trying to test your knowledge or get an "A" to put up on the refrigerator?
Richard
(3,883 Views)
Actually i donot the answer that questions correctly.........
(3,877 Views)
What I meant was: Are you taking this exam currently now? Or, have you taken it already and just want to get more information about these few questions? From what I remember, after you Submit the form, you get explanations of the correct answers when you review your submission.
Richard
(3,870 Views)
no actually i have already taken the exam , in that i took the few quetions which i have doubt ........
(3,866 Views)
#1 2 and 3 look to be correct.  #5 is C.  Stacked and Flat sequences have the same performance.  However, there are ways to avoid any kind of sequence in most situations.  In the cases where you can't, a flat sequence is preferable over a stacked because it avoids hiding code and avoids wiring running the wrong way.
(3,838 Views)
Flat structures avoid Sequence Locals, which, because they contain the word "local", it leads to the idea that we've made a copy of data by using them, but a recent thread discussing sequence locals seemed to suggest that they are not expensive.
Richard
(3,831 Views)
