Choosing a datalogger
I already have the sensors I need those being a nitrate and calcium ISE prope and a Silicon photodiode
I am not at all familiar with dataloggers, what is a good one that I can connect these sensors up to so that I can store the voltage to be read on a PC (after the data has been stored and the sensor is no longer sensing).
Any help is appreciated,
Dan
(2,737 Views)
Hello Dan,
There are several factors that need to be considered when chosing a data acquisition (DAQ) device.  What voltage range will you be measuring, how fast of a sampling rate will you need, and how many channels will you need to sample at once?  Also, what sort of bus interface would you like:  PCI, USB, etc?  The DAQ Advisor webpage is a good place to get started in chosing a device:
http://www.ni.com/dataacquisition/
Chris M.
(2,711 Views)
