Choice of a DAQ board.
i want a DAQ board,as per my project requirements... Attached is the file for level controlling of a non-linear cylindrical tank..
       Moreover i will be requiring a NI sero motor control board as my inlet valve is analog valve with level control...
I have to make a prototype model of cylindrical tank,,in which ultrasonic sensor (YTD which one) will sense the level of water, will pass the signal in controlling loop thru DAQ board and  the analog valve will control the inlet flow.
Kindly suggest me cost effective n efficient boards  shortly as m running out of time.........
(2,314 Views)
You should either call NI directly or your local sales rep.   Go to the main NI web page and in the upper right is a contact us link.
(2,303 Views)
