Checksum (4 characters)
Hello everyone,
I have a serial device with a message-based communication, where it's used 4-characters checksum at the end of message (command).
For example command: "START " (space is included at the end),
in ASCII: "83 84 65 82 84 32",
so the sum is: "430",
this decimal in hexadecimal (4-characters) is: "01AE",
and the desired message is: "START 01AE".
So I tryed this with String To Byte Array and Add Array Elements, but result is only "AE" and I didn't find any solution for fix it.
Thanks in advance for your help.
Message 1 of 9
(6,114 Views)
Convert your decimal number to an array of bytes, then use the "Byte array to string" function.
Regards
Message 2 of 9
(6,106 Views)
You should cast the byte numbers to a 16bit number before adding them.
Message 3 of 9
(6,105 Views)
convert to U16 , sum, split number, add to array    and finally convert to string and send to VISA 🙂
Greetings from Germany
Henrik
LV since v3.1
Message 4 of 9
(6,091 Views)
Meanwhile, I came to this solution.
As with your solution, I still get: "START  ®" But we are close. Smiley Wink
The correct output should be this string: "START 01AE". Any idea how to prevent conversion checksum from HEX to ASCII at Concatenate Strings?
Message 5 of 9
(6,072 Views)
Accepted by topic author Neolker
Using the format into string 🙂
Henrik
LV since v3.1
Message 6 of 9
(6,066 Views)
Great, you are really fast. Thanks a lot! Smiley Happy Last think is Use minimum field width (for checksum part) with 4 characters pad with zeros on left.
Message 7 of 9
(6,057 Views)
You have been to fast 😉 I had edited my solution
Henrik
LV since v3.1
Message 8 of 9
(6,054 Views)
Thank you again, this completely solve my problem. Have a nice day.
Greeatings from Czech Republic,
Martin Wolker
Message 9 of 9
(6,046 Views)
