Checking what VI's are running on a cRIO
Good morning fellow LabVIEW developers,
I have been doing some research on launching multiple parallel VI's on a cRIO 9014 platform. In order to make my research substantially easier, I would like to know if there exists a method of easily checking which VI's are currently running on a cRIO. This software piece would be analogous to the Window's Task Manager we are all so familiar with.
Thank you for your time,
AMV
Message 1 of 8
(4,027 Views)
From LV - Tools>NI Distributed System Manager
Message 2 of 8
(4,019 Views)
For some reason, my cRIO does not show up in the "Networked Items" tab. I can ping and deploy though.
Message 3 of 8
(4,014 Views)
Using static or dynamic IP?
Message 4 of 8
(4,011 Views)
All static on a standalone network.
Message 5 of 8
(4,009 Views)
Double check the subnet setting.  Could also be that Distributed System Manager requires something be installed on the RT target as well.
Message 6 of 8
(4,006 Views)
Client and cRIO are both on the same 0.x subnet. I might have to check if something "special" needs to be installed in the RT target. I am running the latest NI RIO 4.0 driver.
Message 7 of 8
(4,003 Views)
Hi DrAlexMV,
Have you tried to add the device manually by IP address?  You can find more information about that here.
Jayme W.
Message 8 of 8
(3,983 Views)
