Showing results forĀ
Search instead forĀ
Did you mean:Ā
Checkbook/Accounting Program
Has anyone used LabView to create a Checkbook/Accounting program? I have been using Quicken for Home & Business and have found problems with this software. I then tried Microsoft Money, there is a unsupported  version still available for use. I found this software to be much more stable and easy to use but doesn't have all the features that I would like. I am thinking about creating my own version with LabView but wanted to check with the community to see if somebody has already invented this wheel?
(3,727 Views)
While it is undoubtedly doable, with sufficient knowledge (of the accounting part as well as LabVIEW), I'm thinking it would be a pretty big project. Quicken has been evolving for quite a while, so the underlying program is pretty mature, I would think, and has had a lot of programmer hours and $ thrown at it. Is there a Quicken "user forum" to look at the issues you are having?
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,716 Views)
There's a saying, "When your only tool is a hammer, every problem looks like a nail".  I have a colleague who has asked me about using LabVIEW to write a "Disk de-duplication routine" (he is very sloppy about orderly backups or Version Control, so tends to have tens of copies of large data and program files on rapidly-filling 2TB disk drives) in LabVIEW.  I said "Yes, but why would you want to?  It would undoubtedly be slower than what's already out there, and probably not as well-thought-out as code that a team who has studied the problem has put together".
When I first learned Fortran (who remembers Fortran?  Fortran II?), I wrote a program to balance my checkbook.  It worked, but those punched cards were a pain ...
(3,706 Views)
