Check if File or Folder exists Issue
I have observed a strange issue with "Check if File or Folder exists". It says file exists even if the string is empty.
AB
Kudos are Accepted
(6,783 Views)
Actually Empty path refers to the mapped drives in the computer. You can check the detailed help for the same.
For the same you should use "<Not a Path>" instead of empty if you are not intended to input a path.
(6,765 Views)
Use Empty path check before checking for Path exists
(6,756 Views)
Accepted by topic author AB@17
(6,754 Views)
The VI itself has the check internally
AB
Kudos are Accepted
(6,743 Views)
