Chart time
OK , first of all, you need to change the  "convert from dynamic data" configuration to output a single waveform (double-click to change). Currently it outputs an array of one waveform, causing to give an array (with one element!) of frequencies and amplitudes with each iteration. Once you do that, you get scalar outputs that index to give a 1D array at the loop boundary. (Your graph did not show anything, because you had millions of plots, each consisting of only one point (which don't show with the default line interpolation).
Then you also need to either add a small wait to the loop, or configure the simulation to simulate acquisition timing.
See how far you get.
Message 11 of 12
(485 Views)
Okay, it makes perfect sense now. It works now, thank you so much. I can only work on it a few hours a week so thank you for having patients with me.
Message 12 of 12
(453 Views)
