Chart monitoring Crash
Hi
I have a problem with Labview 8.5
The code I've attach is a part of my program; I use this loop to monitor the data acquired with DAQmx in other loop.
If I change the panel between Mic, Acc, Mic-Acc no problem.
After if I click on Slow, Labview crash.
Can you try my code to see if it's repetible the error?
With LV 8.0.1 I've never got this problem
Thanks a lot.
Michele
(3,445 Views)
Runs fine here. No Crash.
(3,427 Views)
Hi altenbach
I don't know...
the program indicate that the error is in the lvrt.dll
offset: 006a46f0
or
offset: 006a46c4
(3,409 Views)
Doesn't crash for me, either.
Matt W
(3,391 Views)
No crash for me too.... try repair LabVIEW installation, also you can replace a Timed Loop with a simple while loop, just to see if this is the crash cause.
Fabio
Fabio M.
NI
Principal Engineer
(3,381 Views)
