Chart history lenght
I read that this property can't be set with a property node, but there's no way even to read it?
Message 1 of 8
(4,220 Views)
Hi there, just an idea, you may try to get the history length from the history data using the array size command.
Ierman Gert
Message 2 of 8
(4,211 Views)
That's the current length of actual data; Chart history lenght is a maximum length
Message 3 of 8
(4,209 Views)
Hi Snamprogretti,
why do you want to read it while execution?
It's a setting only available in edit mode, so you ("the programmer") can create/change a numeric constant in the block diagram...
Message 4 of 8
(4,193 Views)
Having to set the same constant in two different places is bad programming style. If i modify the sw in 2011 i'll probably forget it.
Message 5 of 8
(4,189 Views)
Hi Snamprogretti,
when you need a variable sized buffer then there are better things than a chart's history... Smiley Wink
Message 6 of 8
(4,181 Views)
I would like to be able to read this property as well. For example, to do some simple math on it for user notifications.
Personally, I don't like these types of properties that are settable only with RightMouseButton > Dialog Box. Setting the cluster size in Array to Cluster for example (of which I have an Idea in the Idea Exchange). Maybe you should post and Idea if we can't get an answer from someone that knows more than I do (which is 'bout everybody! Smiley Wink)
Richard
Message 7 of 8
(4,177 Views)
When i need a variable sized buffer i use other things, when i need an incremental display i use a chart.
Message 8 of 8
(4,169 Views)
