Chart History Length in Loop
Hello everybody out there using LabVIEW,
The graph of my virtual instrument is only showing 3 values simultaneously although I updated the "Chart History Length..." variable from 1,024 (default?) to 4,096.
To give a few more information: I'm using LabVIEW to plot the values to of DMM of the myDAQ device. In order to generate a graph, I repeat the measurement in a for-loop and send these values to a graph.
Could anyone point me towards additional diagnostics to run in order to pin down the problem?
Kind regards
Message 1 of 25
(4,419 Views)
Is it possible your X-axis is set to only show 3 values?  Right click on the X-axis and set it to auto-scale.
Message 2 of 25
(4,416 Views)
Thanks a lot for your answer.
When I use random numbers (from the function palette) as input, the diagramm is showing all values and the x axis gets dynamically rescaled, which is exactly what I want.
As soon as I use the myDAQ DMM, only 3 values are displayed.
Message 3 of 25
(4,412 Views)
Then post your VI.
We can't debug paragraphs.
Message 4 of 25
(4,408 Views)
Can you post your code for review as well?
Steven Howell
Controls and Instrumentation Engineer
Jacobs Technologies
NASA Johnson Space Center
Message 5 of 25
(4,407 Views)
@RavensFan wrote:
Then post your VI.
Sure we can.  I'll bet you a beer that there is a miss configured DDT in there somewhere.
"Should be" isn't "Is" -Jay
Message 6 of 25
(4,401 Views)
Excuse me. Please find attached the VI.
I started to use LabVIEW only recently.
Therefore, I am not an expert.
Message 7 of 25
(4,395 Views)
That's ok,  you know enough to post and follow advice.   You'll be an expert in no time
Message 8 of 25
(4,392 Views)
Thanks. That's encouraging, but I'm not afraid it's not that easy.
Message 9 of 25
(4,384 Views)
I don't see any reason why your chart wouldn't show more points once you have set the X-axis to autoscale.
What I do see is that your VI will execute the For Loop 5 times, and that will be as fast as the DAQ Assistant can return a data point.  If you keep hitting the run button, you'll see more data points in groups of 5.
Message 10 of 25
(4,370 Views)
