Chart Cursors legend Shows wrong X axis value
Not sure why this is happening but the chart x cursor time value in NXG 2.0 is wrong. As you can see in the pic attached the cursor itself shows the correct time stamp and the x Axis shows the correct time stamp but the Cursor legend does not show the correct time stamp.
Joe.
"NOTHING IS EVER EASY"
Message 1 of 11
(4,179 Views)
Can you attach a simplified version of your code?
Message 2 of 11
(4,169 Views)
All I did was:
  1. Create a Continuous measurement project from the main screen.
  2. Right click on the graph and select cursor legend.
  3. Add a cursor.
  4. Run the VI.
  5. Move cursor around.
I just did these exact steps again and got the same results
Joe.
Message 3 of 11
(4,150 Views)
Hello Joe_H,
Can you clarify what you mean by 'create a continuous measurement project from the main screen'?
Danielle
Message 4 of 11
(4,112 Views)
When you open NXG to the Welcome Screen, there's an option to create a project.  That will take you to the project screen.  (You can also click "Project in the upper right corner)  On this screen, there's a few selections you can make.  One of these is the Continuous Measurement project.  If you select that, you can follow the steps Joe_H posted.
I did try the steps.  But, I'm seeing the time continue to match on both the cursor legend and the cursor itself.  It'd probably help to share more about your system to see if there's anything different between yours and mine.
Message 5 of 11
(4,089 Views)
Thanks BoKnows - that was going to be my next step as well! I agree it would help to know what the difference in the systems as this doesn't seem like a bug.
Message 6 of 11
(4,087 Views)
I'd be careful making that statement.
There are a great number of bugs that require specific conditions to appear.  If bugs were obvious, they'd be more likely to be found during testing.
When I say it didn't manifest in my system, I'm not suggesting it isn't a bug.  Rather, I'm stating I couldn't reproduce it with the steps provided.  As Joe has reproduced this behavior twice, I'd be curious to see what's different between his setup and mine.  I'm not comfortable suggesting we don't have a bug here.
As an extra data point, it would help for you to make the same steps and see if you have behavior that matches either my findings or Joe's.  More data points make it easier to determine what's different between the systems.
Message 7 of 11
(4,080 Views)
What specifics would you like to know about my system? You can contact me if  you would like.
Joe.
Message 8 of 11
(4,040 Views)
Joe,
I'd mostly be interested in resolution and OS to start with.  I'd also be curious to know if you're seeing this on multiple PCs or just the one.  I've tried to reproduce without luck using Windows 10.  As NXG 2.1 released after you posted this thread, I'd also be interested to know if you've tried using 2.1 instead and see the same behavior.
Really, I'm mostly looking for anything that might explain what's different between my system not reproducing and yours reproducing.
Message 9 of 11
(3,931 Views)
I have been able to reproduce this on 3 computers, all with the exact same settings (Same Disk image from IT).
OS is windows 10 and the display settings are 1920 x 1200. I have tested it on multiple display settings, because not every PC is connected to a monitor. One was as low as 1024x768.
Joe.
Message 10 of 11
(3,922 Views)
