Channel Separation - DAQ Assistant
I hope this is easy:  I need to have seperate indicators showing the value for each channel on a thermocouple module containing ~25 thermocouples.  Currently I am using DAQ Assistant and I cannot figure out how to seperate the signals.
(2,596 Views)
Use Select Signal to break out individual signals or convert it to an arry using From DDT VIs.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(2,586 Views)
