Changing the Property Node label does not update the Terminal/Control label?
@Jeff-P wrote:
Yes, the current behavior is consistent with other similar labels on the block diagram (they are editable),
What is "similar"?
You can edit the label of primitives, e.g. you can change the label of the add function to "multiply", but you cannot change the label of other functions, e.g. show the label of "Simple Error Handler" or "FFT" and it won't let you change it.
Things are not as consistent as one might think. 😉
Message 31 of 33
(1,494 Views)
By similar I was referring to the behavior of non-linked property nodes and invoke nodes, as well as the primitive functions in LabVIEW like add or bundle. As you pointed out, there are a number of functions that do not let you change the name (such as Simple Error Handler) but I would guess this is because they are being run as subVIs instead of primitives, and it is not possible to change the labels on subVIs (if you show labels on those functions such as FFT and Simple Error Handler they seem to be all .vi). It seems consistent but that is just my opinion!
Message 32 of 33
(1,485 Views)
CAR 339553 discussed in this thread has been fixed in LabVIEW 2013. For a more complete list of bugs fixed in LabVIEW 2013, check the LabVIEW 2013 Bug Fixes. You can download an evaluation copy of LabVIEW 2013 at http://www.ni.com/trylabview/ or if you have an earlier version of LabVIEW installed and an active SSP subscription, you will be able to download the latest version of LabVIEW through NI Update Service.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
Message 33 of 33
(1,440 Views)
