Changing text colours on a boolean control
@paul_cardinale wrote:
Perhaps something like this.
How did you actually make that?
Message 11 of 21
(1,475 Views)
Hi marshaul,
customize a (classic) button using two different images for OFF and ON state…
Message 12 of 21
(1,464 Views)
But the text fields are fields, not part of a static image.
Message 13 of 21
(1,459 Views)
that's the boolean text...
Message 14 of 21
(1,452 Views)
Right. And the color changes with true/false change. And I'm wondering how he did that.
That's quite literally the entire subject of this thread, btw.
Message 15 of 21
(1,450 Views)
Hi marshaul,
As I wrote before: customize a classic boolean button by replacing the images for OFF and ON states!
Did you read the LabVIEW help on "customizing controls"?
Message 16 of 21
(1,442 Views)
Setting the "OFF" colors to white and the "ON" colors to black causes the boolean text to toggle between black (for OFF), and white (for ON).  Since I've imported images for the buttons, the Colors[4] property has no other effect (except on the boolean text).
Message 17 of 21
(1,437 Views)
@GerdW wrote:
Hi marshaul,
As it happens, I have read that. Since we're sharing non sequiturs, I've also read this thread *cough cough*.
Message 18 of 21
(1,435 Views)
Ah, thanks. You're actually taking advantage of labview's automatic use of white text on a black (in this case only nominally "black") background. Which means you can only use white OR black and some second color, but not e.g. red and green. Which is why I couldn't figure it out before.
Thanks for responding to the question at hand instead of your own assumptions.
Message 19 of 21
(1,434 Views)
@GerdW wrote:
Hi marshaul,
But he wants the boolean text to be changeable at runtime, so you can't use images of "OFF" & "ON".  You have to use the trick with the Colors[4] property to get boolean text to change color with the boolean state.
Message 20 of 21
(1,433 Views)
