Changing runtime menu item names dynamically in executable
I want to change the language of my application dynamically. In the run-time menu i do this by changing de item names (leaving de item tags the same) In Labview (6.1) this works but in a application builder build executable this don't work.
(3,330 Views)
How are you changing the runtime menu dynamically? Are you reading the menu settings from a file? If so you might be losing the path to the file in the executable.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,330 Views)
I agree with Mikeporter. Also you should wire uo your error clusters with the appropriate indicator.
(3,330 Views)
Mike and you are right. I desided to leave the items names unchanged if the're not in the ini-file with translations.
In the executable the ini-file was not correct included so all the item names kept unchanged.
Thanks for your help.
Gerben Litjens
(3,330 Views)
