Changing one DIO port on NI USB- 6008.
Hello!!
I have a problem whit changing just one Digital outport on my USB- 6008. I have looked on the examples, but they show a update of 8 ports using binary translation. This makes it much more difficult because I dont want to have to trouble looking at the other 7 ports or setting them.
How should I do?
Please give me an example!
/Krille
(2,914 Views)
Hi Krille,
here is an example. The DAQmx Base Write To Line sub-VI writes a specified state to a single line preserving the previous values of all other lines on the port.
Hope it helps
(2,901 Views)
Indiana,
Do you, by chance, have a vi similar to this for inputs? I am having the same problem, and am unable to modify the VI in a way as to make it work..
Any help is greatlly appreciated.
-Alexander S. McGee
Alexander S. McGee
Test Lab Co-op
Stryker, Instruments Division
www.stryker.com
(2,863 Views)
Alexander,
i´m not sure understand you right. But why do you want to do that ?
What is the disadvantage of your application if you´re reading the complete port with an example shipped with Daqmx Base drivers ( i.e. Read Dig Port.vi ) ?
Regards
Indiana
(2,817 Views)
