Changing from LabVIEW 8.2 to LabVIEW 2020
In the past, I have been using LabVIEW 8.2 with the USB to GPIB interface NI-488.2. This week I have just downloaded LabVIEW 2020. Will I still be able to use the old USB to GPIB NI-488.2 hardware? Should I download the new firmware for the NI-488.2?
Thank You,
Gary
(2,369 Views)
Not likely.  That is a LONG time between versions and the latest NI-488 driver might not work with your device.  But you can give it a try.  I did manage to fool my Windows 10 computer in thinking my really old USB-GPIB device was a modern version.  I eventually found a modern USB-GPIB controller and swapped it out.
(2,364 Views)
What model is your GPIB device? I still use M-series DAQmx devices from that timeframe with latest DAQmx hardware. I'd say you have a decent shot at it, but not 100%.
(2,339 Views)
