Changing colour of my curve
Hello dear community of Labview ,
I am a newbie in LabVIEW and am face to a problem. I request your helps please .
I have created a state machine and in the sinus state, I want to change the colour of my curve for each relaunch of the sinus state. Do you know how to do that? I am thinkink about 2-3 weeks ago with any solutions
Thank you in advance for your answers!
Ngoc-Vinh Truong
Message 1 of 10
(4,335 Views)
Hi Ngoc-Vinh,
Do you want to change the color of the full plot (1) or do you want to see several sine waves in different colors (2)?
1: set the color of the plot using a property node of the XY graph
2: create an array of plots and assign a different color to each plot
Item 2 becomes easy once you get rid of the BuildXYGraph-ExpressVI…
Message 2 of 10
(4,322 Views)
The plot color is a property of the graph. Right-click on the XY-Graph terminal, click on Create -> Property, then navigate downward in the properties list until you find Plot -> Plot Color. Right click on the property node and select Change to Write.
Now you can connect a constant to the property node and see what happens. As you want to change the colour every time, you need to select or generate it automatically. In the Graphics&Sound -> Picture Functions palette, you can find useful functions.
Paolo
Message 3 of 10
(4,320 Views)
I want to see several curves in differents colors (2). I have already worked on it (see attachement) but I have a bug on my main program so I prefer to downgrade my program to the easy way ( build XY)
Do you have an idea to change the color with the function "build XY" ?
Message 4 of 10
(4,309 Views)
Pincpanter,
I have already think about this solution but I do not know how it works. I try to connect the property node to a constant but the curve does not change color
Message 5 of 10
(4,305 Views)
Hi vinh,
It will not change the color when you wire a constant…
In your case the problem are the plot properties you have set for the plot: make the plot legend visible and change the plot properties to show a line between the point. The line will use the color of your color constant!
On the other VI: you reall yshould not use ExpressVI functions (like JoinSignal) and DDT wires in such a VI…
Message 6 of 10
(4,298 Views)
So what do you advice me to do ?
Because I do not understand what do you mean by :
"create an array of plots and assign a different color to each plot"
Do you mean by creating a shift register and creating a array?
After that step,  I do not follow you by assigning a different color to each plot ( How do you wire that ?)
Sorry, I am lost ...
Sincerely,
Ngoc-Vinh Truong
Message 7 of 10
(4,279 Views)
Tim
GHSP
Message 8 of 10
(4,270 Views)
Thank you for your answer but I do not think you , it will help me.
I write that I am in the sinus state but in this state, I do not use sine wave, I have used function random number 0 to 1 and the index ( refer to my Vi)
Do you have another answer to give me please ?
Thank you
Message 9 of 10
(4,248 Views)
My example showed you how to do what you need to do. You need to replace the sine wave generator and add what you need to do. I was not trying to solve your problem that is your homework. I simply showed you how to achieve your goal. You still need to figure out a few things on your own.
Tim
GHSP
Message 10 of 10
(4,239 Views)
