Changing a parameter
Dear all,
I've put a modem in a temperature chamber in order to examine temperature influence on modem's performance. As a start, I wrote a VI which set the temperature chamber (serial interface) to -30 degrees and then read modem's performance. This works fine.
Now, i would like to expand my VI to the following:
Setting temperature chamber to (-30) - (+60) degrees (10 degrees step)
Reading modem's performance In each temperature.
Please advise how to do so.
I've LabVIEW 8.2
Uri Haim - uhaim@vyyo.com
(2,783 Views)
Hi Uri,
put your existing vi into a loop and increment the temperature every iteration by 10K (or use iteration count: T=i*10-30).
(2,777 Views)
