Changing VI type from dynamic to static within a class
I have a class that contains both static and dynamic VIs (see attached jpeg).  Is there an easy way to change the dynamic VIs to static ones, without having to recreate them?
(4,776 Views)
Try opening your dynamic VIs and viewing their Connector Pane. Right click dynamic dispatch input terminal and select This Connection Is >> Required or Recommended instead of Dynamic Dispatch. Repeat the process with the dynamic dispatch output terminal. That will change your VIs into static VIs.
Jarrod S.
(4,769 Views)
Thanks!
(4,754 Views)
