Changing Chart Data Types
I know this is a stupid question, but I can't figure for the life of me how to do it. I want to create a histogram, so I stick a waveform chart onto my VI. Fine, now I found the Moving Histogram PtByPt.vi example (ships with LabView 7). It creates a histogram and the data it sends to it is a cluster. This is very convenient because you just wrap your XY data up into a cluster and send it into the chart. Right now I can cut and paste the chart from this example, but if I didn't have the example I'd create a waveform chat, create my cluster with my xy data and pass it in. However, LabView complains about bad data types, because the default input data type is a 2D array of doubles. HOW DO I CHANGE THE DATA TYPE THE CHART ACCEPTS? I've been through every menu and property that I can think of, what's the secret? I've had this problem happen a couple of times and usually gotten around it by right clicking my lead and then picking to create something from a list and when it's created it's created with the right data type. However, it doesn't have that option in this situation. So what do I do? I've included a junk of my code for you to see if you want.
Thanks for any help,
Chris
(3,398 Views)
You've got two different types of graphs. You have the XY graph wired to the cluster and you have a regular (not XY) graph. The regular graph does not accept the same type of input as the XY graph. It accepts a 1D  x array, 2D array (multichannel) a waveform data type, an array of waveforms (multichannels), and a cluster that contists of a y array, x0, and dx (essentially a waveform data type)
(3,394 Views)
