Change values of Tabs on Tab Control
I have a LabVIEW application where it is possible to change the language on the front panel, in connection with this I want to change the names/labels of the Tabs on a Tab Control.
Is this possible?
Message 1 of 8
(5,686 Views)
Hi Labbie,
yes it is possible. See the attachment.
Mike
Message 2 of 8
(5,677 Views)
See attached LV8.5 example and post again if you have further questions.
Message 3 of 8
(5,675 Views)
Thank you! 🙂
Message 4 of 8
(5,675 Views)
I can't open the last example because I got LabVIEW 8.2, not 8.5...
Message 5 of 8
(5,672 Views)
Here is it in LV8.0
Message Edité par JB le 03-26-2008 03:33 PM
Message 6 of 8
(5,663 Views)
It is possible. It is not as straightforward as changing some other properties.
First, on the front panel go to each tab and deselect Advanced >> Make caption match page label. This needs to be done for each tab, once per tab control is not sufficient.
Next, create a property node from the tab control set to read the Pages property. This produces an array of refnums for the tab pages. In a for loop autoindex the refnums and connect to a property node Tab Caption. Feed an array of strings with the new captions and you have changed the appearance of the tabs!
Close the refnums.
Lynn
Message 7 of 8
(5,654 Views)
Awesome all... got what i needed.
Peace,
Pete
Message 8 of 8
(5,596 Views)
