Change the default button in a dialog box
Is there a way to set which button is the default (responds to Enter) button in a dialog box? The things I can think of is either to swap the positions of the Yes/No buttons, or to make your own dialog box VI.
(4,178 Views)
Yes.
Message Edited by jcarmody on 12-16-2008 08:59 AM
Jim
(4,167 Views)
What you did was create your own dialog box. I think that if you use the built in LV dialog boxes, you should have this option.
(4,134 Views)
I'm not sure I understand your question. Are you asking how to do it, or are you suggesting a feature change? If you're asking how to do it, the built-in dialog boxes don't allow for that as they are. You have to spin your own. If you're asking for a feature change, then you can submit a product suggestion.
(4,114 Views)
I wanted to first know if it was possible without coding albeit a relatively simple VI to do that. I think I will suggest it. Thanks.
(4,109 Views)
