Change slide indicator from straight line to arc
I would like to change the path of the pointer on a slide indicator from a straight line to an arc. Can this be done ? I have tried importing different shapes for the slide bar, but the slide bar stays rectanglular with the imported new shape in the rectangular boundary. I even tried modifing the meter indicator, but cannot change the arc radius.
Any thoughts on this topic would be appreciated.
Pat k
Pat
(2,619 Views)
Maybe you can do that more easily if you modify the "Meter" control instead.
Attached is a meter control with a slide indicator.
Best regards;
E. Vargas
www.vartortech.com
(2,619 Views)
