Change sampling rate from AI in a DAQ
I've found this code for defining the sampling rate in a DAQ system. However, in my case I would need to change this rate from time to time. How could I do it without changing the sampling rate at every cycle of the loop? Is there any nice way to do it with interruptions or similarly?
(2,861 Views)
If you want to use single while loop structure of the VI, then you can use the following approach, as on the snippet.
(2,831 Views)
