Change format of all timestamp
 Hi!
I would like to change the display format of all timestamp controls of my project. Is there a way to select all timestamp controls (or to find them) at the same time?
Thanks!
(2,732 Views)
Hi Raffa,
you can use property and invoke nodes to
- get all VIs in a project
- to get all controls on the frontpanel of a VI
- to check the control type (is it a timestamp control?)
- to set the display format of the timestamp controls…
(2,717 Views)
@GerdW wrote:
Hi Raffa,
In addition to Gerds advice, Swap all timestamp controls with a strict typedef! that way you can globally change it for when the client changes their mind again.
"Should be" isn't "Is" -Jay
(2,711 Views)
