Change font with a bottom.
I couldn't find an answer for this but: Is there a way to chnage the font in the front panel by pressing a button?
As you can see, I am building a farily simple starwars-theme-application, what I want to to is to use that funky starwar font ( like the one os top of the siganl inputs), but when a button is press the font goes back to a readable font (ie; arial)
(2,575 Views)
Accepted by topic author Roddy
You can create a property node for each of the controls you want to change.  Write the font name to the property Label.FontName.
(2,572 Views)
