Change decimal point dynamically
Is there a way to change dynamically the decimal point used in numeric control without restarting application?
With decimal point localized, that's work only when restarting the application...
(3,474 Views)
Yes, you can by changing the Format string:
Changing it from '%.;%f' will use a dot as decimal sign. If you change the format string into '%,;%f' will use comma.d
You have to do this for every control you want to change, so creating some framework is usefull.
Ton
My LabVIEW Ideas
(3,461 Views)
ahhh Yes! Thank you.
I don't remember of this property node!
Smiley Very Happy
(3,450 Views)
