Change control values on button press
For that many items, I would make a single input of the variant datatype.  Have 50 different actions in your enum defining which item you want to update.  In the respective case for each action, use a Variant to Data function to convert it to the right datatype and update the appropriate item in the cluster.
Message 11 of 14
(1,137 Views)
Another alternative would be to use an array of variants (if the data is different) or an array of clusters (all the entries use the same set of data, just multiple versions of it) and then use an index or some ID to access the data you are interested. I will see if I could put together a simple example.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 14
(1,119 Views)
Accepted by topic author Siniz
As promised, here is a simple example. I included both an 8.6 and 8.0 versions of the example.
Mark Yedinak
LabVIEW Champion
Message 13 of 14
(1,114 Views)
Thanks guys, and yet again Mark! That is coming in handy 🙂
Message 14 of 14
(1,088 Views)
