Change axes label w.r.t the scale automatically in waveform graph
Hi
Is it possible to change the X-axis and Y-axis labels according to the scale automatically ? I have a waveform graph which is auto scaled and the values on the Y axis changes from milli, micro and nano volts depending on the output results of the tests conducted. I need the label of the axis to change automatically as per the scale.......Could some one please tell me how to do this. Thankyou in advance.
Best Regards
Pratheek
(3,225 Views)
You have the X scale and Y scale Name Label property using that check the incoming values, based on that set the labels accordingly.
(3,218 Views)
Hi
Thanks for the reply.........I'm familiar abt the Name lable property node but how could I assing this propery to an value which I get from an instrument ? Could you please help me with any relevant example if possible....... i'm fairly new to LabVIEW
Regards
Pratheek
(3,210 Views)
Accepted by topic author pratheek
Pratheek,
I am not sure exactly what you want.
If you just want the scale to change to read 10n or 5u, use the scale format property set to SI Notation.
If you want to change the text of the scale name label, you use the YScale.NameLbl.Text Property. The attached VI shows one way to do something like this.
Lynn
(3,179 Views)
