Change an existing controls style
I'm in the process of upgrading a large application from LV 8 to 2011. I would also like to update the UI to use the System control style instead of Classic, which is the current style. Is there a way of modifying a controls style without having to right-click on each control, selecting Replace, and then the control you want?
(6,854 Views)
(6,833 Views)
I got a script started for you. For the script, you just need to do duplicate case for each type of controls that you want to modify.  I already did the numeric and string cases for you.
(6,827 Views)
Your utility works nicely! Thank you.
(6,813 Views)
For the Style's property node in your script, there is a Values[] property.  Can you tell me how you create it?  I can't find that property.
(6,805 Views)
