Change adaptar NI ethernet
Hello to all.
I have 4 ethernets in my PC.
I have just installed NI MAX and I can see the next in adapter ethernets:
The problem is when I connect my camera in ethernet 1 (intel ethernet connection adapter) because NI MAX says me something about jumbo frames when I try to acquire an image.
I would like to change the adapter in ethernet 1 to "Basler GigE Vision Adapter" then I will have all ethernets with the same adapter...
So is there any way to change adapter in ethernet 1? is it possible?
Thanks a lot.
(1,676 Views)
if you right click on the Ethernet 1 and select properties>>configure>>(advanced tab)>>jumbo frames
 you may be able to enable them depending on the driver of that first Ethernet card...
(1,666 Views)
